1 - 11 of 11 Posts
My jeep started making this really loud screeching noise, it goes away when i press the clutch, i turn up the tunes when im driving because man is it annoying, also i noticed my oil pressure gage jumps way up when in gear. anyone have this happen before? any advice will help out alot THANKS!
excuse my noobness, how much am i looking to spend getting someone to fix it? also, is it something that needs to be taken care of immediately?
Well that depends on how much you like to walk. As far as the price it will vary a great deal. The best way would be to do it yourself.
http://www.autopartswarehouse.com/s...ywheels+&+Components,wpn_scat_name:Clutch+Kit)
Sears: Online department store featuring appliances, tools, fitness equipment and more
About $120 for the cluch
And $200 for the tools
A weekend of your time and you get to keep the tools for free and save about$100
Knows a couple things...
I seriously doubt the noise is caused by the throw out bearing. the throw out bearing only spins when the clutch pedal is stepped down on. when the clutch pedal is up, the throw out bearings do not rotate or spin. I am thinking more along the lines of the pressure plate or the clutch disk itself.
so pretty much i need a new clutch kit?
what are the risks if i keep driving as is, just until i get the money to fix it?
cowboys are doing terrible and now this :mad:
thanks again for the replies guys
Clutch change
I just had my clutch and throw out bearing changed, parts about $60, labor $400. It is tough to do in your driveway, the trans/transfer case is pretty heavy.
im about to do my TO in my jeep it was squeeling just a little bit in gear driving and terribly with the clutch pushed in, i bought the part for 51$ and it calls for 2.4 hours to replace, so it should take about 3 hours in my driveway
It's impossible to really know what specifically is wrong until you have the transmission out so you can see the clutch, pressure plate, throwout bearing, etc.
But if I have the transmission out, I doubt I'd be replacing any single component. That's the time to replace the clutch, pressure plate, throwout bearing, and pilot bearing since pulling the tranny is such a PITA. The entire kit that has all that is only $150 or so from Dial-A-Clutch - Your LuK Clutch Kit Specialist Go with the standard (not Gold) Luk clutch kit, it's the best going for the TJ.
Discussion Starter · #11 ·
ok thats what i will do then, thanks for all the help guys. Haynes manual in hand, wish me luck!
1 - 11 of 11 Posts
