I went mudding today for about five minutes during lunch. It was mostly muddy water, and nothing deeper than the bottom of my doors. The Jeep seemed to run okay after I was done but after work I noticed it bogging out occasionally at random speeds. If I punch the throttle it will start to bog out. Sometimes stopping at idle will make it bog out. I pulled the codes from the check engine light and these are what I'm getting: 12,33,24,55
The only code that seemed like was the problem was 24 which said thad it's the TPS sensor. I replaced it two years ago. Any ideas if that is the issue and there a way to check if it is without purchasing a new sensor first.
1991 - fuel injected - V6 - Manual Trans.
