Recently I found out that my jeep has a leak. I noticed after moderate rain my driver side floor mat/carpet is soaked with water. Sometime it is full above the carpet of water. Also after heavy rain my passenger side floor gets wet. This is only below the carpet and my floor mat doesn't get wet. I just cleaned out the cowl drain (and got some gunk out) so I will see what happens with that. It has happened with both my hard and soft tops. I did notice that my driver side door is a little bent out near the front top but not to the point of causing a leak. Any thoughts on what could cause this? Thanks
I know the seal at the top of my door was pinched one time it poured and my carpet was the same the way it dripped it hit the carpet and not mat once I fixed the door seal prob not but fingers crossed its that easy hope it helps
