99 4.0 standard:
I have an oil leak coming from possibly my transmission. It only seems to appear after the jeep has been driven. I recently had a garage change the tranny oil and xfer case oil. Leak appeared after this mtc work. I dropped the skid plate to investigate. Since jeep was sitting no leak ever appeared. Hoped it was just spilled oil under the skid. No such luck.
I suspect that the source is one of the 4 bolts that are under the skid and go into the bottom of the transmission. Can anyone identify what the 4 bolts are? Possibly the drain or a filter access area? Wondering if some kind of gasket has failed. . .
Also, the oil appears to be motor oil. Is that right for a standard tranny?
Knows a couple things...
Those are only the nuts and bolts that hold the transmission mount in place. They would not/could not be the source of a leak.
I know my valve cover gasket is leaking from when I replaced the spark plugs. Got a new one waiting for the weekend to install. I'm seeing a drop of oil where the trans bolts up to the engine. I'm hoping this will take care of it. If not, new main rear seal it is...
I'll have to check. I just don't see a path going clear back to the skid. I would think I'd see a trail of oil. Good suggestions. Thanks
On mine the 4 bolts were the ones that bolted the trans to the skid plate. I recently changed my trans oil, filter and gasket. That took care of that leak. The leak I was referring to is coming from either the rear part of the valve cover gasket or the rear main seal. I'm going to do the easier first.
