Learning the bottom side of my first Jeep, found these two lines on the passenger side. They're just hanging in the air unsuspended - one is borderline fine, but the other, more flexible, swings freely and is probably hitting the body at the top of the swing and the crossmember at the bottom. Is this an assembly oversight, a bracket fallen out, or it's the way JK is designed?
Just looked at my '16 JKU and there is a bracket attached to the side of the bell housing that holds both lines in place.
I think it is the same as what you are showing.
Cheers
I he been under mine with some ty-wraps and used a few. I had those lines loose also, but not now. Probably not a big deal as most people never see the underside, much less actually inspect and ty-wrap things.
