1 - 20 of 37 Posts
I'm looking for a 2.5"-3" JKU suspension lift kit with shocks. I'm wanting a good brand that won't break the bank too much. Any ideas on what to get?
Vendor
There are a bunch of threads on the best brands. I would suggest piecing something together. We have all the Suspension Components you need to build a nice kit. Rock Krawler makes good control arms and track bars. There are a lot of quality springs out there, you would need the correct length and rate for your particular Jeep. Bilstien makes good shocks among others.
Let me know what questions you have or what you'd like a quote on!
-Ryan
I believe that they are saying you should go look at their lift kits and choose one. There are alot of options out there. Pick the one that's right for you.
^ well there you have it. Right back where you started lol.
That's the issue with asking that type of question.
Cheap, DD and want great shocks. The Rancho kit is a nice option.
All around DD Teraflex, RK, MC, AEV
Comes down to budget and use of jeep. Remember, most your aftermarket coils will ride firmer, and rated to handle weight.
My wife lover the ride of the AEV 2.5"-3.0" JK DualSport XT Suspension Tripple/Pregressive.
There is not enough space to add my comments. All GOOD!!!!!!!!
Realize its an opinion and a dam good one.
Rubicon Express 2.5" spring lift with No Shocks. ($380)
http://www.4wheelparts.com/Lift-Kit...ks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R/ERE7141
Then buy 4 Rancho Adjustable RS9000XL shocks for $328 (but have a $100 rebate, making Net cost $228).
http://www.4wheelparts.com/Lift-Kit...c=1&t_s=90&t_pt=3306&t_pn=S/DShockingRS9000XL
Add this Rock Krawler Adjustable Front Track Bar ($141)
http://www.4wheelparts.com/Lift-Kit....aspx?t_c=1&t_s=101&t_pt=4164&t_pn=RKSRK02024
Total expenditure after rebate $750 Dollars.
Boom.
If you can afford it, add in either this
Rancho Control Arm Brackets ($140)
http://www.4wheelparts.com/Fabricat...aspx?t_c=86&t_s=527&t_pt=8342&t_pn=RANRS6250B
or
Rock Krawler Control Arms Adjustable $280
http://www.4wheelparts.com/Lift-Kit....aspx?t_c=1&t_s=101&t_pt=3158&t_pn=RKSRK02015
890 or 1030 total, shipped, with quality-ish components.
How's that for specific.
Quality components and I doubt you can find a better quality to price ratio.
Edited to provide working links.
All of the options are good but not equal. :)
The RE does offers good value as does the TF and a good balance of on and off road performance. The RK, AEV and MC offer the best performance but at a premium for an equivalent lift kit. You can't go wrong with any of these choices. Read some of threads on the virtues of these lift kits.
Highly recommend you leave the engineering to the manufacturer and you bu the lift kit from one manufacturer and avoid building a Frankenlift no one can help you troubleshoot. Double check that all parts are torqued correctly and were not installed while the suspension was binding.
I disagree. Sure it may be more convenient to have one manufacturer, but any troubleshooting process is exactly the same.
Having just did a lift, the bigger question to me was how are you gonna have it installed. Install can cost more than the lift. I decided to save the money and do it myself. Adjustments seem easy, but I was off on a couple. Jam nuts are a pain. I hate Jam nuts. While I love my lift (RK), I found out latter that MC arms came adjusted and tightened for the 3.5 inch lift (only). If you do it yourself then take it in for an alignment by a 4x4 shop. Also, you adding bigger tires? If so what will you do with the spare. I bought a new rear bumper.
So what I'm saying is think through, all the work and additional parts. You'll be happy in the end.
Rubicon Express Part RE7141 - 2.5 Inch Standard Coil Lift Kit - No Shocks - - 4 Wheel Parts
Rancho Part S/DShockingRS9000XL - 4 Rancho RS9000XL Shocks with 4 Red Shock Boots - - 4 Wheel Parts
Rock Krawler Part RK02024 - Bomb Proof Front Track Bar - - 4 Wheel Parts
Boom.
Rancho Part RS6250B - Control Arm Correction Brackets - - 4 Wheel Parts
or
Rock Krawler Part RK02015 - High Clearance Lower Control Arms - - 4 Wheel Parts
I don't have a bunch of Jeep lift experience, but my research would agree with this approach. And yes to the control arm drop brackets if you DD your Jeep.
I might use the Rancho RS7000 series shocks...
Bookmarked for reference when the time comes. :beerdrinking:
1 - 20 of 37 Posts
