100661 - 100680 of 100731 Posts
Got it, cool, then you have up to like 20a to the fuse breakout you added for easy power access (if you are using that tap as recommended through the 14-16 gauge wire they have on that tap).
Might not be necessary to go hotter for your needs though - just trying to be helpful in avoiding a coyote works type incident :cry: when loading that (up to) 100a breakout in the kick.
Really apreciate the posting of this with links btw. I did purchase one of those fuse blocks based on your writeup. Thanks! (y)
I brought in a 20a battery tap today in the same manner from the 12v power outlet tap. In my deployment, my intention is to use these for very low-amp circuits - camera, led lights, etc.. Anything more than a 10amp draw warrants a separate relay (of which, I currently have two, that handle the halo lighting - one that handles the headlight halo, the other that handles the ancillary halos on the turn indicators, side indicators, and fogs; check the video for the context).
2017 JKR...
Do they make one for a 2 door now or is that a 4 door rack modified?
They make one for a 2 door now. He just finished them up last week. He has them on his site as of today.
I got the emergency brake adjusted and it’s definitely better. Everything looked good, so no new brake pads or anything was required.
Sunrider installed and put in a dead pedal in prep for a long trip...and noticed an axle seal leak. Great more work i don't have time for.
Reactions: Izzy Does It
Installed and wired up a replacement 3rd brake light. I had to rewire as whomever removed the factory one simply hacked the wire out. :mad:
4495429
4495430
4495432
4495433
4495434
4495436
4495438
4495440
4495441
Was it expensive to get done? I know I could DIY it but I'd rather just have a shop look over mine. I am doing a couple of trips within the next month so would like to get it looked at.
It cost me some brake cleaner, a brake spoon and a few hours. I don't take my vehicles for brake work unless I can't get the components apart. That happened with a Yukon with 150k and they had to heat the rear drums.
Reactions: CJK2017 and Mr. JP
NE Ohio. Took the top off for the year. I’m not a “use the soft-top as it was intended” guy. I pulled off all the hardware. Doors still on for now.
Wish we could leave ours off. It sits outside and I'm not gonna leave it open to the elements. We did take the front part of the roof off today while running errands. You say NEO? What part? We're in Akron
Wish we could leave ours off all summer also...wife got a little jiggy with the small summer tires on her jk with the top down for the 1st time today...can't keep the tops open for even the evening here as weather changes constantly and critters get in and party without cleaning up after themselves. :rolleyes:
4495457
Nowhere near Akron though....
Installed a Bestop Sunrider on my wife's JKU. Not super happy with the fitment. The front and sides fit nice and tight, but the rear is pulling up and there's a gap between the sunrider seal and hard top. I've contacted @Bestop support and emailed them pictures but they say to expect it to take a day or so before I receive a response. So for now, it's parked in the garage with the threat of rain. I had hoped to install the core doors on my JK but the unexpected issue took up my available time waiting on hold, talking, taking pictures, etc.
Reactions: Mr. JP
So today I upgraded the spare tire carrier.
4495562
4495564
After removing the stock hinges it did shift a little.
4495566
4495567
4495568
4495569
so while opening the tailgate this happened, I have just removed it for now. I am looking for a stronger option.
4495571
4495572
Other than the limiting arm popping out, I only had one other problem. I have to tap one bolt hole one the center carrier itself. I will take care of that Thursday hopefully.
