I have a 1994 2.5L 4cyl wrangler automatic and If I put 32s on the tires will I just lose a little power but still be able to cruise down the highway.
You will lose a little bit of power but you can still cruise. Shouldn't be an issue I wouldn't think.bhsanchez72 said:I have a 1994 2.5L 4cyl wrangler automatic and If I put 32s on the tires will I just lose a little power but still be able to cruise down the highway.
You are completely wrong becuase it says AUTOMATIC and I have 3.73 gears.I think up to a 30 inch tire, you won't notice. Every inch above that is going to start robbing more and more of your cruising power until you no longer have a 5th gear. At 33 inch tires, even after my tuneup, I still top out in 4th gear at about 60MPH and have no 5th gear on even flat ground at that speed. I lose power right away. I'm running the same 4.10 gears you are so I'm going to 4.88 front and back to get some of that power back.
