1" lower in front is a desirable stance. that way when you load a bunch of stuff or passengers in the back you're not dragging your rear end all around.My 2004 LJ has a 2" spring spacer boost but the front is about 1" lower than rear. I hear a 3" spacer is not advisable, so I'm wondering what coil springs I should get to level it out.
Thoughts?
Thanks,
BB
Yup, those are the ones I got. Good price and people seem to rate them similar or just below OME.Interesting - so you have 2" coil spacers in back and 2" springs in front and it is almost level?
These the ones?
BDS Jeep Wrangler TJ 2" Front Coil Kit Pro-Ride Coil Kit (Pair)
I wouldn't go taller than a 3" spring, the coil rate would have to be very very low for the proper stance.So here's the question:
I have a 2004 LJ with a 2" coil spacer lift. The front currently sits about an inch or more lower than the rear. I'm looking at buying a Q9000 winch and this Barricade bumper:
http://www.extremeterrain.com/barricade-front-bumper-j20851.html
I plan on replacing the springs and am not sure whether to get 3" or 4" springs to level the jeep out. What do you recommend?
