Ihave an 87 Wrangler with a 5 speed that I will be towing. Does it matter what gear it's in when towing (other than neutral or reverse)?
never tow in overdrive that's asking for tranny problems, (the 258 probably couldn't do it anyways)
If you mean you will be flat towing the jeep then technically any gear works including reverse BUT I always use 5th gear on the rational that if the t case ever managed to not be in N then at least the engine would not overspeed and maybe not be destroyed.
if you are towing the jeep as in tires on the ground behind a RV do Neutral tranny and transfer.
If towing the jeep as in on a trailer first-5th gear in 2wd just properly chain it up.
If towing as if I'm towing things with my Jeep try and keep the Jeep above 3rpms for power
