Extended the shifter
A few years ago I bought an AX15 transmission to replace my ailing BA10 trans. The shifter that came with the transmission came with the threaded end broken off.
Fast forward to a few months ago, I bought an AX15 trans from a '95 Cherokee with an external clutch slave cylinder. With a couple lemons, I decided to make lemonade.
Pic @1 is both shifters. While the Cherokee shifter was undamaged, it's shaped wrong and is too short. I decided to extend the broken shifter to compensate for my body lift and repair the broken threaded end.
Pic #2 is where I had originally intended to use a piece of pipe as a collar to reinforce the joint. The inside diameter of the pipe was too big and would have made a sloppy fit.
Pic #3 is where I got a couple pieces of small angle iron and began welding them to extend the shifter. The extension adds 2" and my Jeep is running a 1" body lift, so the shifter is actually an inch closer to my hand (once installed).
Pic #4 is the welded and ground shifter.
Pic #5 is after a bit of Bondo, primer and paint.
I'm still awaiting a transmission mount from Advanced Adapters and once I have that, I'll replace my old BA10, and put in a new LUK clutch to go with the external slave cylinder transmission from the Cherokee.
Good Luck, L.M.
