...in the engine compartment under the ps unit/brake resevoir in my '04 Wrangler? It has several drain holes and three tapped holes in a triangular configuration.
If you remove it you can carry a quart of oil, tranny fluid, and power steering fluid, inflatable doll. You know, essential crap....in the engine compartment under the ps unit/brake resevoir in my '04 Wrangler? It has several drain holes and three tapped holes in a triangular configuration.
Oh yea! Drop a couple MRE's down there for hot chow.i like lunchbox idea better.. keeps the food warm![]()
If you remove it you can carry.....inflatable doll. You know, essential crap.
It'd be a little warm.Good point. Then I can use the extra room for a six pack.
coffee pot to go along with the heat? :really:Roger on that, better use one of those small coolers.
