1 - 9 of 9 Posts
Did you check the wheel cylinder? It's either brake fluid or gear oil, I'm thinking brake fluid. Pull the drum and have a look.
Yeah that looks like brake fluid to me. My dually just did that and I wouldn't have known right away but I put it on the lift to do my exhaust and saw the fluid.
Just take the cap off of the master cylinder, if it is brake fluid, the smaller of the 2 reservoirs will be low. If it isn't low, then that wetness is gear oil from a bad axle seal.
1 - 9 of 9 Posts
