1 - 12 of 12 Posts
I'm swapping a stock airbox in for a K&N CAI that was installed by the PO and found that I am missing this hose:
it is 3/4" ID on the airbox side and 5/8" on the connection to the hard tube running to the valve cover.
I've been googling for an hour and have found the part on the 3.8 ("make up air hose") which is obviously not right and then I've found this one
https://www.moparpartdepot.com/oem-parts/mopar-pcv-hose-68083250ab
Which obviously does not look right.
Does anyone know the actual name and part number of this molded hose? For now I managed to jam a 5/8" heater hose on there, but it is putting pressure on the alternator harness, so I'd rather replace it with the correct molded hose.
Thanks in advance!
Reactions: vanhalo
Make Up Air Hose - Mopar (52022313AB)
now go give a wino a dollar.
So I've looked at that part and the diagrams and photos look nothing like what I"m seeing..
Thanks in advance!
This is PCV intake hose, 52022313AB
Thanks. THat's two votes for #52022313AB. The weird thing is that a Google image search (and pulling that number on sites that sell it) displays an image of a hose that looks nothing like the original picture I posted.
Weird.
I guess for $15 I'll take a chance that the photos online are wrong.
Thanks gents!
I got the part number off the part so unless jeep put the wrong part number on....
Reactions: Cummins_Powered
Is that the hard tube that clips to the valve cover or just the rubber portion that attaches to the air box? (Perhaps it’s sold as an assembly and that’s what is throwing me off...?)
Pretty sure it's the whole enchilada
Aha! I finally found a good enough resolution image to see it. You're right. I just need the part indicated in yellow, but the entire assembly must be purchsed.
Thankfully it was only $17 on amazon with shipping.
Thanks again!
Thanks again!
Lol. I am in the process of doing the exact same thing. Took me an hour or so to find this thread.
Now I know what to buy.
I was going to replace it today with stock but realized I needed this part.
Discussion Starter · #12 ·
Yep! 4 hours of internet research and 5 minuted to install the part. lol. Now I have a backup plastic tube if I ever need it...
Reactions: vanhalo
1 - 12 of 12 Posts
