1 - 13 of 13 Posts
Don't know but I just found one identical to it! Looks like a vacuum line with no vacuum on it,,, LOL
When I find a mystery vacuum line I move it around the engine bay as far as it reaches in every direction. I normally find where it goes.
it is a.........................?probably the vent valve. part of the vaccum system. follow it back and you should end up at the txfr case. see map.
Discussion Starter #8
Well I was looking to fix my heat issues and this check valve just snapped when I was moving things around. Any need to worry?
Discussion Starter #12
Drpinkydo said:
It's a check valve. Its not supposed to connect to anything. Just leave it hang.
But is snapped right where it bends to curve down. Still no need to worry?
1 - 13 of 13 Posts
