I'm in the process of making the PO's wiring neat under the dash. And I found a couple things that are unknown to me.
First is a relay (?) Of some sort. Its a black box with 4 prongs. One prong had a red wire that was plugged into the "cruise" spot in the fuse pannel. And there were two blue wires attached to two if the other prongs. The blue wires didn't go anywhere and the box wasnt mounted so I took it out.
The second thing is a vacuum connection. Its a plastic piece with two vacuum lines that come from the dash. I don't know what this is for, but my first thought was my non functional 4wd light.
Any thoughts?
the relay is something the PO put in for something aftermarket.. good thing you pulled it out, looking at the great job they did wiring it up LOL.
The relay could still be used for a number of things, so hold on to it. Just do a little better wiring it up than they did :thumb:
