bottom should attach to a little nub on the top of the axel, as kJeeper said, the other end just needs to be up high.. IIRC mine was on a little hanger/holder but i yanked it off and stuffed it up higher, just dangling/jammed next to something.
So the hose appears to be attached at the axle. The white plug on the top of that hose is the breather.
IIRC, the original routing attaches the spring clip of the breather to the tub just on top of the passenger rear upper spring saddle.
Ya know...
This might be a good time to extend that line even higher. There are some kits available to do this, and they include the front axle, transfer case and transmission as well.
Just in case "global warming" is a real thing. ;)
