Looks like someone installed a bolt onto the cad housing. Locking your shift fork over permanently. They must have cut the wires and took out the vacuum lines, since they are no longer needed.joshpowell16 said:Here's the other side. I don't see vacuum wires anywhere.
Nope, it's not full time four wheel drive, it's just your front axle is live. Your transfer case is disengaged, so you aren't putting power to the front.What mod are you talking about, how did you essentially bypass the vacuum canister deal on the axle? And when doing so that makes it all the time 4 wheel drive?
Look at the stickies coyote did a write up about it and no it makes it like a tj axle which is essentially one piece and when you switch the xcase into 4hi or lo it puts it in 4wd and when in 2wd the front axle is just all one shaft basicallyredneck1984 said:What mod are you talking about, how did you essentially bypass the vacuum canister deal on the axle? And when doing so that makes it all the time 4 wheel drive?
I just posted a link at the same time lolCDennyRun said:
