It's the vacuum nipple on the right side of the valve cover. I need the elbow coming off that nipple because mines rotted. Thought it was the PCV but the parts stores are coming up with a totally different PCV elbow part. I have the 2.5l.
All 1991-1995' with a 2.5L engine have a CCV (crank case ventilation) system.
Towards the front of the engine, right side (if your looking at the jeep head on) you will have a CCV fitting that kinda pokes out the side of the valve cover. In the back you have a Fresh air inlet, which pumps in fresh air from your air box.
Mine doesn't have an elbow, just a piece of rubber that you can buy from an auto parts store. In the back where the fresh air inlet is, I'm pretty positive you have to get the top part and the hose that goes to the box from the dealer.
Pic related:
Yeah. this line is going to something right below the steering shaft not the airbox. trying to research it right now.
OK did research and it is the CCV fitting. Thanks for the help
Discussion Starter #6
my buddy must of followed the hose wrong but you're correct and answered my question. looks to be a dealer only part. Thanks for your help!
