1 - 9 of 9 Posts
Knows a couple things...
So it should be plugged in? I can just fix this myself?
It's already "plugged in" on top of the differential where it serves only as an air vent for the axle housing. Just route the loose end of that rubber hose up along the passenger side of the radiator where plastic clips should be there to hold it. The end of that hose should end up an inch or so below the top of the radiator.
If the clip is missing or broken, just zip tie it in to "secure it" in about the same location.
1 - 9 of 9 Posts
