Morning ... Thanks sirWelcome to the forum. This is the thread you want to read. Post your question in there, Kjeeper is a pretty sharp helpful fellow. http://www.wranglerforum.com/f202/newbys-guide-to-lifting-your-jk-298665.html
http://www.wranglerforum.com/f202/most-popular-lift-setup-on-wf-1136938.htmlGo look up teraflex 2.5, that's a popular one.
Is there a reason to avoid the frame side rear track bracket? Just a weaker point or what? I'm running the frame bracket, figured if it was a liability they'd probably go w axle brackets in the kit.
The axle side bracket provides a better overall geometry. It isn't an issue of reliability, the preference is based on performance.Is there a reason to avoid the frame side rear track bracket? Just a weaker point or what? I'm running the frame bracket, figured if it was a liability they'd probably go w axle brackets in the kit.
