like everything else I do, I go about it the hard and long way. this winter im small block chevy converting my YJ. I have a 85' sb350 one piece rear seal, and a TCI th350 auto tranny. I will be using a Ford 8.8 rear axle from a 95' explorer. Im keeping the D30 up front for the first year, and switching it nxt winter. (im not engaging 4x4 untill i loose the D30) SO, now i need a transfer case! like an idiot, i bought one from craigs list; its a 92' np241 from a chevy truck. Come to find out this WONT bolt up to the th350. so what t-case do I need? ohh, i went to a junk yard and looked at a t-case that was mounted to a th350 and it was the same size as the dang tranny.....this is way to big!PLEASE HELP!!!!!
try advance adapters or novak they might have an adapter plate to make that transfer case work.....
i hear that the np231 will fair fine behind the 350 as long as it is mostly stock, also from what i understand the np205 is good too. there are lost of other options like a dana 300 but that will need a flip kit to make it drive drop...its like 500 something last time i priced it. and i think your dana 30 is gonna be fine behind it. don't bail on using 4 wheel just cause the axle. it should be fine as long as you show some reserve on the trail..jsut a little!!! novak makes a mount and so does advance adaptors, and some others but i think novak really specializes with chevy conversions, as a matter of fact they give oyu all the strength facts with the axles and tcases and what not...heres the link
http://www.novak-adapt.com/
have fun and good luck...
Discussion Starter #4 (Edited)
yeah guys I looked at both those sites already, and the adapter to my jeep's t-case is like $480.00 bucks! thats insane... i'd rather put a chvy case on it and spend the money on good drive shafts. is'nt there any chvy case that will bolt to a th350? what about chvy light trucks from the late 70's? or what other vehicles did chvy have that were 4x4 and used a th350? but, if it has to be the adapter then i guess thats what it has to be...o'hh and the motor will produce around 300hp it's a guess from what i've heard about how i have it set up. all standard overhauling has been done, w/ edelbrk eps intake- matched cam and lifters (eps) edlebrk perform elec choke carb-elec. fan- serp. belt set up. i know, its not injected...but its all my budget could allow.
roll with the np205 and get yourself a twin stick kit. or...you could always look into the 203/205 doubler combo. :punk:
Discussion Starter #6
so....forgive me but what is a twin stick kit? and while were at it,...whats a doubler combo?
Discussion Starter #7
if its not a straight forward application (ie. adapter or factory joinable t-case) i dont want it (unless its near bullet-proof) i dont like divorced set-ups or really "backyard" cobbling.
the 205 case was commonly found behind a 350 trans....
a'here ya go quick example search....
twin sticks for the 205
http://www.offroad-tech.com/tech/twinstick205/
doubler setup for 203/205
http://www.fourwheeler.com/techarticles/drivetrain/129_0705_transfer_case_doubler_kit/index.html
here's my heep as it was a few weeks ago....running a chevy 350 on propane, 350 trans, and 205 case w/ twin sticks, 60 front/14 bolt rear, full hydro kit in the brown truck on it's way to my house. :punk:
