1 - 20 of 36 Posts
33" or 35"? 285/70/17 or 285/75/17? i have a 2012 2 door jk. i plan on a 2.5" lift. just cant decide which tires to buy. i love the look of 35" tires but hear they are very hard on a jeep and the gas mileage really drops. any and all opinions are very welcome. help me please.
I AM THERE4 I JEEP
If money is an issue, stay away from 35s. You gotta pay to play.
i'm back
yep... ESPs dead on! :thumb:
ask yourself why are you throwing the larger tires and lift on your rig. if you're not going to do much offroad... hell even if you are, 33s are a fine choice.
the second and third order effects are much less with 33s. less need to regear, gas mileage isn't as impacted, tire size and weight aren't typically as big a concern for the tailgate, axle reiforcement can wait a bit....
now... i know a guy, :whistling: pretty close to you, with a brand new set of 33s that'd look bad arse on your rig now. lift or no lift....
:popcorn:
i don't mind paying the money but i also wonder what all i will need to put on the 35's and do it right. i like the look of the 35's with a 2 1/2" lift. if i would go with 33's what kind of set up would you recommend? sometimes i see 33's on 2012 jk's and i think they look too small. and if i go with 33's should i lift or not? all help is greatly appreciated.
thanks Gjersey84! i like the 33's but what size rims? i was thinking 17x9. what looks best with 33's?
Discussion Starter · #11 ·
hey pappyglide that looks sweet. any lift? and what backspacing on those rims? thanks
Do what I did and go right in the middle: Either 295/70R17 or 305/70R17. I have 295/70R17 and they measure 33.6" thereabouts, equivalent to my buddies 35" KM2's (which run small I'd assume?). 305/70R17 measure out to 34". Both tire sizes are about 12" wide. The 295/70R17 will be cheaper than the 305/70R17, which cost more than an equivalent 35" tire; hence the reason I went with the 295. Good luck! :thumb:
Discussion Starter · #15 ·
i am a lil confused. you said 295/70R17 but your description says toyo 33's. i am seeing cooper in your pic though. the coopers are stock correct? are the 295's as hard on things as the 35's? and do they look better than 33/12.5/17 with a 2.5" lift?
That all depends on what you want to do with your jeep. Some people say you can do it "right" for a few hundred bones. Or you could do it "RIGHT" for around 20 grand. Its all up to you.
sorry mudrunner i mixed up your post withwassup.
LOL. My JKU came with Goodyear 255/75/17's I installed the TeraFlex Leveling kit and Cooper Discovery AT3 285/70/17's.
They are a great tire and have excellent reviews. They also fill up the wheel well like it should be.
Do what I did. Make it LOOK like you have giant tires. Get wheels that stick out a bit (like Level 8 trackers) with 33" duratracs. Youll be light but look great!
Yeah, my actual profile says the 295/70R17. They will be harder that some light 33's but not as hard as 35s as you can expect as they are between the two tire sizes. Here is a pic.
1 - 20 of 36 Posts
