1 - 12 of 12 Posts
2001 Wrangler Sport
springr said:
Besides the factory skids what are the minimum skids needed? I am planning on ACE rocker guards, steering skid and oil pan skid. What else?
Depends on your style of wheeling, I'd do a steering box skid too
Knows a couple things...
Oil pan protection is the #1 priority, the gas tank is the #1 with early TJs having inadeqate protection for the gas tank. What year TJ do you have? I don't recall exactly when the factory went to an adequate skidplate for the gas tank, sometime in the 2000-2001 timeframe or so.
Jerry, will the 00-01 factory skid fit an earlier model (99) TJ? You never know what you might come across at the local junkyard!
I think the 2003+ models have the stouter tank skid. What lift and tire size are you running or planning on?
Gas skids should be compatible throughout the 97-06 period, at least I think... The 00-01 skid still maintains the flimsy design that I used to run.
The gas tank skids are a direct swap. I swapped my 98 for an 03-06 and it was no problem at all. Bolted right up
Any reccommendations on where to get oil pan, auto trans and steering box skids? Mine is an 03 Wrangler. All stock. I may put a 2"BB lift on by next summer.
Depends on what you're looking for. Look at Under Cover Fab for some awesome skids that protect both the engine and transmission. I believe their engine skid will bolt up to your existing transfercase skid plate and also their new ones if you ever decide to do a tummy tuck.
Steering box skids are even simpler; they're all pretty much the same. I like my Rokmen skid.
That is just one option for each. There are many out there; time to start searching.
Oil Pan
Gas tank
Steering box
Rockers
diff covers
That's the order of what i hit the most. If it weren't for my UCF engine skid my transmission/oil pan would be hammered. My stock 05 gas tank is dented pretty badly, and may get an upgrade soon. And if it weren't for my steering box skid that would be hit several times already. :)
Depending on what you do i might start with rockers. Dented tubs aren't cool. Diff covers are at the bottom of the list, I've only whacked my front one a few times enough to where i was glad to have the beefier cover.
1 - 12 of 12 Posts
