1 - 12 of 12 Posts
my jeep is gettin fuel i think ..... but it aint firing and it aint the distributor so what else would it be the coil............:banghead:
what year is your jeep? 2.5,4.2,4.0 ? more info the better,maybe we can help.
2.5 1995
A little bit more information would be helpful, but here's my experience: I have a 94 2.5L, 5 speed. It was fine, and before it died it the revs were bouncing alot..thought, because of that, maybe the CPS (Crank Position Sensor) was dying and then finally went. I replaced that..and nothing. So I checked the distributor, fine. Replaced the coil...nothing. Turns out it was the PCM or ECU, whichever you want to call it. My suggestion is try this: Make sure you are getting power TO the coil. If you are, check if you are then getting any at the spark plugs. If you aren't, and it's not the distributor..my bet is that it is PCM/ECU. It's not that bad-really easy to uninstall and install...can be a pain in the @$$ to find one though. Ebay ended up working for me...If I were you, I'd check craigslist, if it ends up being that. (Never did find out if my CPS needed replacement...but it doesn't bounce anymore, so hey.)
ok thank you sooo much i have tried every thin i changed the crank sensor and the distributor then it ran fine for like a month then the same thing and now i aint getting any fire to the distributor so idk but hey thanks man i really appreciate it i will try it then see what happens thanks again ........:D
after birthday glow
could be an ignition control module to they say they either work or don't work if the cps don't help
Discussion Starter #7
i will check that hey what does soa conversion mean just wonderin
Discussion Starter #9
ohhhhhh duh i knew that i tried it on my yj it was harder then i thought and then i realized i also dont have tha funds soooo it was a no go
after birthday glow
not really that hard if u have the tools and the time u can make it work with not that much effort but i dont blame u for not wanting to take on something that may be out of ur skill range or tool range
Discussion Starter #11
oh it aint out of my skill range or tool range but i just didnt want to be with out my jeep i am going to college 4 days a week and i didnt really have all the money for tires/shocks/rims/and all the other stuff at the time but now i am gitting them peace by peace but u got to do what u got to do:zap:
after birthday glow
yeah i hear u that's what is kinda stoping me right now i just don't have the time
1 - 12 of 12 Posts
