I would say impact driver, torch, and a gun to kill who-ever invented the torx head.
I would say impact driver, torch, and a gun to kill who-ever invented the torx head.Ok I will be coming from a miata and the tools to virtually take the entire car apart are a 10,12,14,17,19, and 21mm wrench. I have been able to do crazy things with just that.
What tools are used most ofter or what tools are indiscpensible for the wrangler owner to do maintenance?
The only tools that I am aware of are a T40 torn socket. Anything else that a new to wrangler owner should have?
Thanks
Hahaha .. F'n torx headsmrbat23 said:I would say impact driver, torch, and a gun to kill who-ever invented the torx head.
x2.I hate to be the bearer of bad news but our TJs require nearly every size tool known to mankind. The drivetrain is mostly SAE (inch) hardware and the rest of it is mostly metric.... but metric and SAE sizes are scattered everywhere.
nope. only 3000lb capacity and doesn't lift high enough.yah so is this a good jack for wrangler use? on sale for $60 Racing Jack with Rapid Pump®, Compact, 1.5 Ton, Aluminum
yes, thats normal, and yes thats a metric shit ton.Ive been doing some research and found more info on the costco arcan jack. It seems to be great but weighs a metric shit ton. I mean 100lb jack. Damn. is that too heavy. If that seams normal for a jack I might get that then.
yes, you have to have a costco membership to shop at costco.That was my thought process. I will probably leave it in the garage. I was trying to find info online about buying the floor jack at costco. Do you have to have a costco membership? That is being really though to answer right now.
