1 - 12 of 12 Posts
Hi everyone!
First time post. Just wanted to see if anyone could tell me their best guess of the size of the wheels and tires in the attached pic. I found this Jeep in a post on the AliExpress app. I really like the stance of this Jeep and want to model my Jeep on it. Let me know what you think. Thanks!
Retired Moderator
:welcome: to the Forum..:wavey:
Reactions: BSpringmeyer
I have 20 inch wheels with a -18 offset on 275/55/20 it has a similar stance. I would say 20 due to the tread to rim distance. My buddy has 18 in wheels and has more tire from the wheel to the tread. We both have 9 inch wheels with - offset.
Definitely 20" wheels... Tires don't appear to be 12.5 wides, so I'd guess 295/60r20's.
Lots of tires in that size.
Hi!
Can anyone please tell me if theres going to be rubbing on my stock Sahara if I run 275/60R20? If not- how big can I run before needing a lift/spacers.
Tnx!
Tnx!
Going to be difficult to verify that for you. Very few people here run 20's on a Jeep. A 275/60R20 is slightly taller than the tire that we usually say is a 50/50 proposition. But it's narrower so it might just sneak in there. Make sure you get a wheel that has around 5.0 back spacing, like a 9" wide with 0 offset.
Here, I don't really care for 20's... But these would look sweet.
Blowing up the image, it's a Falken Wildpeak A/T tire.
Based on some rough measurements, I'd take an educated guess at 305/55R20 and if not that, my second choice is 325/60R20.
Nice looking set!
These I've got on order ..issue still remains what size would look best and not cause rubbing.
1.38" off set 20X9 Jeep SRT8 wheels I run 275/60 20 Falken Wildpeaks AT3. Just had to trim the front air-dam a very small amount so it didn't rub at full lock. 37 PSI Avoid E rated tires, makes a noticeable difference in ride quality. Tire sidewall remains just even with the fender flare.
1 - 12 of 12 Posts
