I had to replace the wheel speed sensor on the front wheel. Inside the bearing is some white lubricant? Do I need to lube the sensor or just pop it in?
The o-ring should be lubed a little to keep it from tearing during installation. I reached into the hub with a dental pick and got just a dab of the white grease, which I used to grease the o-ring.
