Bought a set of LRG11721073324N
The wheels center fine on the rear.
The wheels do not center at all on the front hubs.
Do I have to use hub spacers?
If the wheels don't fit factory hub ring, what will be different with spacers?
Am I just plain scr..d?
Your only screwed if the hub bore is too small on the rim to fit. Sounds like u just need to find the correct spacer.
Bad pic of the ones I run with my rims.
Should be same on both ends no?
Sent from my SAMSUNG-SM-G891A using Tapatalk
I think that's exactly whats occurring. The front hub center ring is larger than that of the rear. The ID of the bore on the wheel is too small and thus can't seat flush against the rotor on the front axle.
Did you remove the clips on the lug bolts that are used to retain the rotors during factory assembly? OEM wheels have a slight recess milled in the back to clear them and some aftermarket wheels do not. If your LRG wheels do not have the recesses and the clips are still on your rotors that can cause an issue.
The clips are not needed once the Jeep leaves the assembly line and may keep an aftermarket wheel from fully seating on the hub.
Reactions: Wandell
Yes, they are still there. Good idea. thanks.
It seems unlikely that the front and rear wheels would have different diameter hub centers. It could be, I haven't measured. But on mine the front and rear wheels fit exactly the same, they are hub-centric both front and rear, and the same wheels fit both nicely.
Perhaps it is the rotor clips.
