1 - 9 of 9 Posts
The backspacing is good for the 15" (3.44) wheel as you usually need more to clear the brake calipers than you would on a 16" or 17" where 4.5" is fine for a 12.5" wide wheel.
The bolt pattern is wrong on the wheel you selected 5-114.3. It needs to be 5-127 for a JK/U
Tweak beat me to it.
Yes they should as the backspacing is good for a 15" wheel which means it should clear the calipers fine you just won't be able to run a larger brake kit is all. Many here run a similar setup.
One other note. My tires stick out from the fenders about 1.5 -2" to the sidewall with 4.5" of backspacing so a 3.44" backspaced wheel is going to stick out quite a bit, just a fyi in case there are legal issues where you live about that.
That's my biggest concern. I have a TJ and they stick out a good bit. But to be going that far past the flares on a JK seems like a bit much to me. I'll look some more and try to find a similar wheel with a little less back spacing
Thanks for the info and quick responses!
1 - 9 of 9 Posts
