1 - 13 of 13 Posts
right now I'm currently running 35s on the stock Rubicon wheels. Looking to upgrade the wheels and really interested in knowing what offset the stock wheels would be and if anybody has pictures of there Wheel and Tire set up with information on size and offset. I'm pretty sure I do not want a positive offset however until I see pictures how can I really know! I've picked out wheels on the internet ranging everywhere from 0 to -44 offset, just need to decide the look I want. Thanks in advance!
The most common setup among JK owners is a 9 inch wide wheel with 4.5 inches of backspacing/-12mm offset with a 12.50 inch wide tire.
j5 by Wandell Asbell, on Flickr
j6 by Wandell Asbell, on Flickr
Reactions: Heavy-Metal
I believe that would look pretty good. I currently have factory wheels with two Inch spacers. Of course I have flat fenders so it's going to look like it sticks out even further.
Anybody know what the backspacing would be on a factory Rubicon wheel?
One Happy Camper
Reactions: mrcarcrazy
Retired Moderator
Apparently I don't know how to upload using Photobucket anymore.. Ginger_crusader on Instagram
http://www.wranglerforum.com/f2/how-to-post-a-picture-1939746.html
^^^This will help you to post your PICS..
^^^These charts will help you to understand Wheels: Width, Back Spacing and offset.
For 35's, wheels with a 8.0, 8.5, or 9.0" of Rim width will work for you. Back Spacing of 5.0 to 4.5 will give you the clearance, along with a nice wide stance.
What you currently are running, is a factory installed 6.25 of Back Spacing. Then you added the 2.0" adapters = 4.25 of Back Spacing.
I wouldn't go any wider than 4.5 BS, because it will effect your scrub radius, handling characteristic's and add additional stress on your Ball Joints and Hub Bearings.
@jazzy jeff
When it comes to wheel specs on a Jeep, you can completely ignore offset. Focus on back spacing. You need a maximum of 5" and more than 4" unless you are going to run 37" or larger tires. The common sizes are 4.75" and 4.5" with most manufacturers.
This site will help you with the specs if you can only find offset:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Vendor
I will add in here that the way to calc backspacing, if you do not have a chart to look at is:
rim width plus .5" +/- offset.
This will let you know where you are at when you find those cool wheels you can't live without and don't know if they will fit. Like beadlocks from DV8 Offroad. :)
Have a great day!
Allen
It's not you, it's Photobucket. Unless you subscribe to the top level of storage for $399 a year you can no longer share photos.
1 - 13 of 13 Posts
