I removed some KC lights that were installed on my Jeep when I bought it. It was a spider web of wires under there and apparently at some point I clipped the wrong wire and it led me to the wheel speed sensor on the drivers side front. So now I’m trying to find out where the wire plugs into at the other end. I’ve searched multiple forums and YouTube with no luck.
Can anyone link a wiring diagram or help me out? Push come to shove I’m about to try and trace the passenger side and see if I can find where it plugs in. Thanks in advance!
I don’t have a diagram, but I just went out and looked at mine. It looks like from the sensor at the knuckle it goes up the frame behind the shock tower to a clip. That clip then feeds into a wiring harness that meets the sensor on top of the front differential. That then feeds off to the front of the Jeep along the frame rail into the front bumper channel where the rubicon sway bar disconnect is. From there I couldn’t tell.
Hopefully this helps alleviate some troubleshooting.
