1 - 20 of 24 Posts
I hope I'm not stepping on anyone's toes, but the large thread on here about the MB wheels with duratracts had me about to place the order for a set with the MB Chaos wheels. I ran down to local DT and they beat the DTD price. DTD price was 1530.00 delivered. Figured I had to pay someone to install them so maybe 80 bucs more. The local DT quoted 1499.00. Wheels were 90 each, tires 170. They will also remove sensors from old and install in new. Just thought I'd throw this out there for anyone about to jump on the DTD wagon. One more thing I want to ask, sure this combo will work on my 2010 Wrangler Unlimited, no lift? Thanks.
Man I wish I had a DT near me. The places near me all charge an arm and a leg for anything compared to TR or DT...
Scottmich001 said:
33x12.50r15 with 15x8 wheels
The standard package. :)
Assuming the backspace is good you should be fine.
Scottmich001 said:
I'm not real brilliant about the back spacing specs. However I've seen a few JK's with these wheels. Are there back spacing options with these wheels that I should check before ordering?
4.5 bs is the min I believe.
Retired Moderator
It's two arms of the same company. When I was PMing with DTD, they recommended I also go a check with my local DT store. DTD will be just as happy if you buy from them direct or from your local store.
Assuming you're getting the 15x8 Chaos 5s, it'll work fine for turning left/right without rubbing. Those wheels have 3.75" of backspacing.
As to the lift, you won't need one for driving around on the roads. You will however need either a lift or flat fender flares if you go offroad. The new wheels will push the tires out from under your fender flares, and they'll rub against your fender flares whenever your suspension "flexes" offroad. A lift or flat flares will also make the jeep "look better" in most people's opinion, simply because it's going to look like you've got a whole lot of tire stuffed in there.
3.75 :banghead:
That's what I have.
Where did I get 4.5 from? Ugh.
Retired Moderator
3.75 :banghead:
That's what I have.
You were right--4.5" is about the minimum backspacing you'd want on 8" wide wheels. I think the AEVs get away with 5", but 4.5" is a good guide when selecting wheels. Our Black Rocks have 4" of backspacking.
I'll get it right someday. LOL
Btw I got the leveling kit on. Finally.
Discussion Starter · #12 ·
The 3.75 bs will make tire stick out farther than 4.50 correct? If so will that look ok. Spending 1500.00 I want it to look sweet. I take it the Chaos doesn't have bs options? Sorry to be another newbie pita.
Retired Moderator
Retired Moderator
Retired Moderator
Scottmich001 said:
Ok well I hope I'm making the right decision, I'm about to head to DT and make the purchase. There's a little time left if someone wants to stop me.
It's an appearance issue--will YOU like it is the question. How long have you had the jeep? There's something to be said for just slowing down, looking at pictures, meeting some Jeepers and going wheeling, etc. Educating yourself is a good thing. That said, yes, it should look fine.
kjeeper10 said:
There's nothing stopping you.
What the hell is stopping me :facepalm:
No kidding. Come on slowpoke.
Retired Moderator
I was going to rock the stockers for a bit. I thought the sway/link rub thingy was just with the 12. Or maybe I'm thinking something else.
Anyhoo... Be nice for Goodyear to come through again... Psst, "hey Goodyear--I'm talking to you.. rebate .... Hello?"
Discussion Starter · #20 ·
Done deal!! Placed the order. Was able to squak a couple more bucks off the price. They will remove the tpms of the old and install the new no charge. Total Good Year Wrangler Duratracts 33x12.5R15 on MB Chaos 15x8. For 1484.00 mounted. Thanks for the help.
1 - 20 of 24 Posts
