1 - 9 of 9 Posts
There is a high pitched squeal coming from the front that can be heard only while my jeep is moving. It is noticeably louder as I turn the steering wheel to the right when driving. It does not make the noise if I turn the wheel while stationary. Am I dealing with brake issues or wheel bearings possibly? Any input is appreciated. I'm driving a '08 JKUR I bought used a few months ago. Thanks.
Ok, checked each wheel and squeal is coming from front driver's wheel. Sounds like maybe pads are rubbing. It's the only wheel making that noise. Maybe time for new pads.
As far as moving wheel from 9-3 not sure what is normal but there is slight movement. It seems very minimal to me but I don't have a reference to what is good & what is obviously bad. I have read on this forum about worn out ball joints, I just have never had to deal with those issues.
Discussion Starter #6
No movement is normal. 9-3 would be beatings. 12-6 balljoints (crap ... Should have had you check them also)
Haha no problem, I'll go check 12-6 too. Thanks for the info guys.
Discussion Starter #7
Checked both again: 12-6 no movement, 9-3 slight movement with front wheels. I'll start planning a brake job, wheel bearing replacement all around. At least I'll have a base line to go off of since I don't know PO's maintenance habits. Thanks again.
Discussion Starter #9
I know that day will come. It has 80,000 mi now so it's only a matter of time.
1 - 9 of 9 Posts
