1 - 13 of 13 Posts
Where is the AC drain located on a 2012 Jeep Wrangler?
I've been getting water in both driver and passenger side footwells and wanted to make sure the AC drain was working properly before going further.
Please note: It's probably a good bet it's the AC drain as I haven't washed the Jeep and it hasn't rained since I dried out the footwells. I did run the AC during that time and the moisture is back.
Thanks...
On the engine side of the firewall, down low. Driver's side above the transmission where the firewall meets the tub. Tube sticking out.
:thumb: That's what we are here for. Helping each other out.
Reactions: dmulk
Thanks for the pic, I was going to look into this soon as it's warming up finally. On the TJ I extended the outlet with a piece of hose to keep it from having issues, does the new JKU (2012+) look like it will have issues with blow back or leaking back into the body?
Hi, I discovered this tread and I've been having a liquid draining from the ac drain pipe. Any ideas on how to fix it??
Unless your AC isn't blowing cold anymore it's probably just condensation.
Five years after OP....was on the trail today when I noticed the tranny dripping something around the seal. I freaked because I had just bottomed out but it was only clay. Temps and pressures all checked out and then got under it at home and saw the drain tube. I didn't even think about it being the A/C since I almost never run it (SoCal local here).
lost.. ac drip tube
thanks for the info, I checked that area out the other day but was on my back laying on the ground and did not see it. I will try to get it on a rack and recheck. I found the one on my granddaughter 2013 and thought the 2010 would be in same area but I cant see it!!! Keep looking I suppose.
1 - 13 of 13 Posts
