Pics?moscoeb said:Tj? JK? YJ?
I have an 11 JK and I have mine mounted above the rear view mirror. Just screwed straight to the trim and ran all the wires under trim, and antennae wire through rollbar padding. Very clean look and speaker is easy to hear up there
What parts did you use?? Im going to go the same route but with the cobra 29blkrubi88 said:Home made mount above the rear veiw mirror.
Just a piece of 16 guage flat steel from Lowe's, bent and screwed to the windshield frame, and then I cut a slot into the trim so it would go back on.What parts did you use?? Im going to go the same route but with the cobra 29
Ah ok see i hate chipping paint ect. Im gonna try the footmans loop for the hardtopblkrubi88 said:Just a piece of 16 guage flat steel from Lowe's, bent and screwed to the windshield frame, and then I cut a slot into the trim so it would go back on.
Thats what i plan on doing exactly lol
a parts list would be awesome man if you dont mindCool. If ya need a parts list let me know. Tip: Where the CB touches the plastic windshield liner, put velcro or a thick bit of cloth or something in between to prevent sqeeking.
Everything can be had at Home Depot for a few bucks.a parts list would be awesome man if you dont mind
awesome man i appreciate it! ill be stopping at home depot soon then lol.Everything can be had at Home Depot for a few bucks.
3/8" insulated clips in the electronics section
3/8" #10 pack of nuts and bolts - hardware section
1" L-brackets - in the hook and bracket section
Just tap a new hole on the CB bracket and go from there.
thanks man thats great news!No problems with the latch - you just can't close it all the way. It still works as designed, however. The radio does not stick out too far, it is in perfect reach while driving.
