Anybody out there got lights mounted on windshield brackets? If so where can u run the wires where there not just out in the open and it looks decent. I've got a set of lights on mine but there not wired up an I was just curious where u guys ran the wires.
Also did the same thing as above. Lifted the cowl up and ran the wires through it and out by the hinge of the hood. Then slid the grommet down to the cowl to make it look like the metal cover ran into the jeep.
I always go about 1/2" to the inside of the lower windshield hinge. Drill the hole and put in a grommet, run the wires through and they come into the cab of the jeep behind the dash, up high, but easy to get to and out of the way. Then silicone around the hole to keep water out.
and as you can see on darker jeeps, like my old YJ, the wires don't stand out and I did the exact same spot as my current red YJ
