To start, i have a 92 wrangler with the 4.0 6 cyl, soft top, and its pretty much stock. I have probably spent about $3000 on repairs alone, both DIY and Shop. I finally have 95% of it repaired and want to start upgrading it. Because im in college and dont make a whole lot just yet, im thinking of starting on the interior first. I want to start by rhinolining the inside, replacing seats and the console. then id like to move to the engine with a snorkel, maybe a new throttle body, electric fan and maybe a dual battery tray. I do want to lift it eventually but want to start on smaller stuff first. Any ideas or suggestions?
Find out to what extent you want to wheel your rig first, get out there with a group. The suspension and tires will get you more use out of your dollars. You could have a real beast and still have a factory interior. Roll cage should be at the top of the interior upgrade list. Also consider a hand throttle if you have a stick shift and plan to do rocks.
I plan to go at the end of march when the snow pack melts. since its my dd, i probably wont go bigger then 4" when i have the cash to do so
