Asking the same question in a different post is not going to get you a different answer.
First there are no such thing as Rubicon springs they are not heaver than on other jeep models.
A teraflex leveling kit will level you stock jeep. You need to take 5 minutes and crawl under your jeep and read the tags on your coil springs to know what number you have. You are assuming you have a higher number because it's a rubicon.
There can be no answer to your question until you know what you have stock.
Mine had 14 and dropped about 1 inch giving it the rake back I swapped out the front spring to a 19 and removed 1 of the teraflex pucks and now I'm level again.
If you don't like the answer you might ask the same question a 3rd time.
if you read the first sentence, it doesnt make sence. and for some reason it wont let me edit it, so i made a new post.
