1 - 15 of 15 Posts
Lookin' at a 3 in. suspension lift. I have a RC 1.25 bl already and Allen says I should go with the 4.25 Zone Combo kit and sell off my RC 1.25. My Tj is my dd, but I do some light offroad on the weekends. Mostly fields/mud/logging trails. I'm not worried about having so much flex cus I'm not really going over large rocks or things like that. I've got about a grand to play around with, but the lower the cost the better. :thumb:
I understand that I really don't need an SYE at 3 in of suspension lift, but I'm not a big fan of T-Case drops. So if it comes down to it, I'll get an SYE. I want quick discos, nitro shocks, and a mml in the kit as well.
With all that said, what do you individually recommend? :confused:
Just 33s.
Anyone else?
For 33's a nice way to go and it allows you to avoid the cost of a sye and new shaft is the 2.5in sl and 1-1.25in bl combo. the mml and bl should elimnate any chance of vibes from the 2.5in sl. ajust your bumpstops acordingly and away you go.
Edit: OME is a great way to go but not the cheapest. You get what you pay for in this case
So OME or Rubi Express is what I should be leanin' towards, I'm cool with that. If its within a price range, Im gonna go ahead and get a SYE at the same time. Do I have to get a drive shaft or can I run the stock drive shaft with the SYE if it's too expensive for the combo SYE n shaft?
You can't run your stock shaft with an SYE. SYE stand for slip-yoke eliminator. Your stock drive shaft connects to the slip-yoke on the transfer case, thus when you eliminate said slip-yoke you need a new drive shaft.
What is a CV shaft and why do I want one? - JeepForum.com
You'll also need adjustable rear upper and lower control arms to properly set things up after installing the SYE so plan for those if they don't come with whatever "kit" you end up buying.
Discussion Starter · #12 ·
Thank y'all. I think I'm sticking with the 3 in suspension for now in hopes of not needing the sye with my bl and mml
Just be prepared to drop the t-case a bit (or do something else) in case your mml isn't enough to counter the increased angles brought forth from your 3" lift. If you were only lifting 2"-2.5" I'd say your chances of not having any vibes would be better with only a mml.
1 - 15 of 15 Posts
