1 - 15 of 15 Posts
2014 Rubicon unlimited:
Which tool works best for cutting into the front air dam?
I'm installing brackets for a front tow bar.
Instructions state that some cutting of the air dam may be required.
Dremel, Sawsall, cut off grinder, scissors, tin snips. . .what tool is best for this job?
Grinder with a cutoff disc.
Tinsnips if the hole is big.
Hole saw if it is round.
Go slow !!!
The instruction were mistaken. The air dam needed to be cut.
I used a Dremel tool with a cut-off wheel of about a 2-inch diameter. It easily cut the air dam material.
I trimmed my sisters airdam to fit a brush guard on and used a dremel with a 2" plastic cut off wheel as well and it worked like a charm.
Tin snips or just rip it off!! Lol
1 - 15 of 15 Posts
