I'm due for a valve replacement because of the bad batch of valves. Being that the head has to come off should I check for or replace anything else while it's off?
Also my mechanic is going to replace just the valve set up in cylinder one. Is this ok? or does it stand to reason to do then all. You know what usually happens once you replace one bad thing..the rest usually go ... just saying
anyone with experience with valve replacement?
Also what type or brand valves should I get?
so replacing the "weak valve" issue to fix the code 43 does the head have to be removed?
