Gents,
I recently removed my Currie Anti-rock sway bar and it's related sway bar connecting links and, installed a stock sway bar and, these disconnects you see below in the pictures. The reason I installed the stock sway bar is because I wanted better road manners. The bar came with the disconnects you see. I know they are an older version but, of the research I've done, I can't seem to find them on the net or, any of the 4WD supply houses and catalogs.
I had to figure out how they worked and once I took them apart and lubed some things up, they work pretty slick. So, just some help here. Who made, or, what brand are they and, what vintage? Thanks way in advance.
Scott
223.5 KB
225.1 KB
