1 - 10 of 10 Posts
Retired Moderator
Why do some people do like a 2in susp lift then a say a 1in body lift? Why not just go a 3in susp lift? The only reason I can think of is after they put the susp lift on they decided to go more then added the body lift.
normaly people do a 2 or 3" suspension lift and then do the 1" body lift accompanied with a 1" motor mount lift, MOST of the time this eleminates the need for an sye and cv driveshaft.....most of the time 3" and under on the suspension lift people put a 1" transfer case drop but with the body/motor mount lift you can avoid all that ;]
Retired Moderator
Great info.And doing a mml causes the back of the engine to tip downwards,correct?
did the 1" BL on mine becasue I needed new mounts anyhow, plus it gives me the room for the MM lift.
1 - 10 of 10 Posts
