The problem is that a $8 paper filter works better at filtering the fine particles for our Jeeps. But I do love K&N on my sand toys where sand is clean and can't make it through.
The problem is that a $8 paper filter works better at filtering the fine particles for our Jeeps. But I do love K&N on my sand toys where sand is clean and can't make it through.I have never had any problems with them. They seem to trap lots of dirt/dust if cleaned/oiled correctly-and resusable for no telling how many years. I know my 4.0L jeep motor is a low air flow pump, but if filteration is as good or better than paper- whats not to like?
A simple test to see if you live where K&N's don't work is to pull the air tube off the throttle body after running one and inspect the interior of it and the backside of the TB butterfly for dirt.I have never had any problems with them. They seem to trap lots of dirt/dust if cleaned/oiled correctly-and resusable for no telling how many years. I know my 4.0L jeep motor is a low air flow pump, but if filteration is as good or better than paper- whats not to like?
Well said. It's what my Jeep came to me with and I've been too busy buying CAs and tires to change it out.A simple test to see if you live where K&N's don't work is to pull the air tube off the throttle body after running one and inspect the interior of it and the backside of the TB butterfly for dirt.
In our region, the inside of the tube is almost white with accumulated dirt and the backside of the butterfly will be caked with dirt. Neither of which happens with the paper filter.
So to answer your question, the filtration is not as good when it really needs to be. The rest of that is folks put a pre-filter on and I've yet to see anyone do a test to show the "high flow" ability of a K&N with a pre-filter on it. If you have to run a pre-filter on your filter, you ain't got much of a filter.
Because of ISO lab test results like the below that show it's not even close to as good of an air filter as a paper element filter is.I have never had any problems with them. They seem to trap lots of dirt/dust if cleaned/oiled correctly-and resusable for no telling how many years. I know my 4.0L jeep motor is a low air flow pump, but if filteration is as good or better than paper- whats not to like?
Just wondering, what year was this tested in?Because of ISO lab test results like the below that show it's not even close to as good of an air filter as a paper element filter is.
The below is one of the ISO lab test's charts & their comments.
"In the chart above it’s important to note the different test durations for each filter. The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction. In 60 minutes the AC Filter accumulated 574gms of dirt and passed only 0.4gms. After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms. Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt. "
The above lab test result chart & comments were copied verbatum from the overall test results
After noticing visible accumulation, I opted for the AEM filter which attached to my K&N CAI.In our region, the inside of the tube is almost white with accumulated dirt and the backside of the butterfly will be caked with dirt. Neither of which happens with the paper filter.
