1 - 20 of 143 Posts
I have read through some posts and some of the threads are like 700 posts and I was not about to waste the time thumbing through them.. Most of the posts are "your ac is plugged" or the dealer put this seal on the door etc etc.. So instead of me taking it to the dealer to get the bs run around, I decided to look on my brand new 2 week old wrangler myself.. this is what I found..
While having my GF spray it with the hose..I jumped inside..
Pulled the carpet back..
This is not very comfy..
Leaks right out of the green plug that meets the firewall and side of the body..upper center left of picture, this is located on the passanger side behind the dash..
This is a youtube video I made of it with just a light spray of the hose..
Jeep wrangler 2012 leak - YouTube
Our 2012 JKU leaks too.. Now when I take it to the dealer they can just fix it instead of putting a bandaid on it!
Thats the right way to do it, make a video, and you have proof. Wont have to listen to the dealer bs. I would like to know what they do to fix it, send us a update please.
So that's why mine leaked during that heavy rain I was driving in.
I thought one of my drain plugs came out but I checked. You're right buddy, some of these leak just like you say, don't let anyone tell you otherwise. Mine does the same thing.
Hmmm.... I wonder if some simple silicone would get it done? I get the occasional leak on my 2011 in the passenger footwell, but it is inconsistent.
Reactions: jdinny
The best fix, and to avoid the dealer screwing our vehicles up just a little bit more, you should find out where that area is (meets) on the OUTSIDE of the Jeep, and silicone it from the outside. If you do it from the inside, you would still have water trapped in between the sheetmetal. Would love to have a fix for this from the outside to seal the Jeep up.
I have WeatherTech fitted floor mats on my JKR. The only time I've seen any leak was when we had a side ways rain, and a tiny bit of water ran under the driver side door and onto the floor mat. Looked like a small gap in the gasket. Will try to get it to fit a little better before running through too much water.
I really like the effort by Sicbrian in documenting his issue.
Wow, my leaks but on the driver's side. GREAT FIND!! Subscribed, hope to find a way to fix it myself
BTW, after the first leak, i ripped out the carpet. Probably the best thing I've done to my jeep so far . . .
Discussion Starter · #13 ·
Does anyone have a picture of the passenger side of the jeep with no side skin on it? I looked up from the bottom up and I can only see where the antenna is.. Im wondering if the area where the plug is, on the outside just drains straight down as I can see its all open..
He's no good to me dead.
I had the same leak, it stopped when I installed the mopar door sills. It traveled down the door front against the weather strip and behind the plastic wire guard to the floor, the sill plate slopes away from the cabin and tightens the seal, alleviating the leak
Discussion Starter · #16 ·
Did you see the video? This leak is way away from the door seal...
Discussion Starter · #18 ·
Sorry, vids keep crashing on the phone, from the read it sounded like it was channeled in the trim panel
Nah.... It's up near the firewall, I pulled on the plug thing last night, it is pretty much just sitting right on the top of the metal... I'm going to inject water into it tonight to see if it drains to the outside of the vehicle (like part of the channel that drains from the vent in between the hood and windshield) then I believe it would be possible to seal it from the inside of the cabin.. I don't know how jeep missed something so simple..
Discussion Starter · #20 ·
Ok I couldn't handle it, as soon as I got home from work I had to see where the other side of the "plug" drained to.. this is what I found..
Started off with a turkey injector with some fuel tubing from one of my model airplanes..
Grabbed a "Red Solo Cup" and filled it up, (with water)
Then inserted it into the "plug"
The water leaked out of here..
Here is the youtube video of it leaking...
2012 jeep wrangler leak - YouTube
So I figured I would inject more water to see if it leaked out the same place, and it did...
So my conclusion, you should be able to pull the plug out to the side and RTV it to seal it up without negative effects..
1 - 20 of 143 Posts
