So somebody hit my 02 tj on the driver rear tire while parked and popped it out of gear. Now i have this vibration noise but just on take off. No idea what it can be. Noticed that rear driveshaft goes to the passenger side towards the diff. Not sure if thats normal. Any kind of help would be awesome. Thanks.
Step behind your Jeep and see if you have equal amounts of tire under each fender. Does it stick out more on the drivers side than the passenger side? Was it like that before the strike? That would have been a hard strike if so.
You could have a bent wheel?
You could have a bent axle?
It’s puzzling it only happens at start out.
Get someone to drive it and follow them to see if you can see any wobble.
