I've been doing a lot of reading and im leaning towards getting the zone 4.25" lift. I want to run 35's Will they fit? will they rub? if so how bad?
They will fit on the vehicle, but you'll need some pretty large bump stop extensions to keep the tires out of the fender flares if you're flexing it. If you're staying on the road and you have the proper bump stops you can run this set up.I've been doing a lot of reading and im leaning towards getting the zone 4.25" lift. I want to run 35's Will they fit? will they rub? if so how bad?
