Bolt pattern is correct but I would guess backspacing is the culprit. Not sure without researching it but figure out what backspacing is with -27 offset on that perticular wheel and compare it againt the wheels you have on the jeep now.
The body of the listing says the "compatibility" checker doesn't work for these wheels. They fit but have less back spacing so they will stick out past the stock flairs. Sounds like you'd need wider flairs or lifted high enough to not interfere
