I have 2016 JKU Rubicon that is stock.
I have a chance to pick up a set of 2012 Grand Cherokee 18" wheels with P265/60/18R tires mounted on them.
Would these work on my Rubicon with rubbing or causing problems? They are 5x5 bolt pattern.
According to wheel chart from www.discountedwheelwarehouse.com, the Grand Cherokee rims have a high offset and the Wrangler has a medium offset. Would this present any problems?
Appreciate any help or information you can provide. Thanking all in advance.
thom
It will make the wheels set in even farther, cause rubbing on sway bars and possibly other front end components. Plus look bad moving it in.
They will clear the brakes, but if you love those rims you'll need wheel spacers to reduce rubbing like Txrdstr said.
Thanks for the replies. I think I will continue to look for 17-18" Wrangler rims.
Thom
